Paint Brush For PC Cleaning
Solved by Marvzl1357,
Well, from what I know, and the airbrush I have, the pressure (~30psi) from the airbrush is hardly strong enough to dislodge any dust clumps.
So, probably not
Sorry, sorry, I thought you saud airbrush for some reason.
if you're cleaning your fans, maybe get a big or medium sized, medium-stiff brush and it should work fine.
But ONLY use it on your fans otherwise it would produce static left right and center, so it would be a bit dangerous to use a brush on anything other than fans
