I put 1.515v before vdroop the other day through mine and that was on a low end msi z77a g45 board. If you have a high end board and are only doing it for benchmarks then you can put it that high no problem.
Sky Pollution | i5 3570k @4.8Ghz | MSi z77a g45 | MSi GTX 770 Gaming 2gb | Samsung 840 Evo 250gb, Samsung OEM 500gb HDD | Corsair CX750m | Corsair 760t White Edition |
Corsair M95 | SuperLux 668b's | Logitech C615 | ViewSonic VX2250wm | Random OEM keyboard until I rage break it and grab another random OEM keyboard from my pile.
Build Log: http://linustechtips.com/main/topic/186413-sky-pollution-my-white-760t-build-rebuildupgrade/
Thats a LOT!!!! How bad is the vdroop?
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
how many volts is it on @4.5?
I wouldn't go above 1.3V
Most people draw the line a 1.3v
4.5ghz and 1.1 dont mind me -_-
What would you guys say for temps. im trying to stay around 80c
Most people when stress testing want to keep it below 90c. It will never get that hot under normal load though.
Simple Stryker (Now Finished  ;) )
The Terrible HP
Not super bad i think it dropped it down to like 1.475. I was just trying to get stable on a 5ghz oc just to see if my chip could even do it. Surprisingly my h320 kept it under 90c at that high.
If you are benching anything up to 1.52v is fine for brief periods of time. Like if you are trying to do 5GHz bench runs. But for daily usage don't go over 1.4v. With Ivy however you will probably hit a heat wall before 1.4v unless you are delidded.
Max temp on Ivy is 105C. Usually below 85C for max temp loads is more than acceptable.
