SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/188994-difference-between-these-two-kits/
Both links are the same, m9.
They're not unless they have listed the same product twice
COOLING:
dey iz nat. One is 26909 and the other is 26908.
I don't see why they wouldn't work on an 1150 motherboard.
EDIT: The LED colours are different
Yeah, I kind of fucked up there. That 9 snuck up on me.
How to Post Topics, the Right Way / The Ultimate Build Parts List
"4 words. DON'T BE A DUMBASS" ~@Swndlr
9 is always a sneaky mothertrucker.
Where did you read that?
COOLING:
In the description.
They'll be fine, except it'll depend on what CPU you use for what frequency you set the kits to. For example, Celeron/Pentium don't support 1600mhz RAM speeds usually. This is more dependant on your motherboard for higher end CPUs, however.
I believe the difference between these two kits are that one has Red/Green LEDs (you can swap between colors) within the top of the heat spreader, and the other one, the 26908 product id kit on pccasegear, has Orange/Blue.
They're both 16GB (2x8GB) Crucial Ballistix 1.5v 1600mhz CL9/PC12800 kits, just different color LEDs. I could be wrong, but I'm almost 100% certain I'm correct. Also, the R/G LED kit is out of stock for a few days, just a heads up.
Edit: Didn't read any of the replies or most of the page until now.. :x. I just know Tactical Tracer kits have LEDs in them and the product codes were only different by having XRGX or XOBX so I assumed it was LED color differences. Oh well.
