Its 10 Pro better! :P
Stick with the 840, no need to dump it just because there's a new kid on the block, unless you have money to burn.
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2538579
I don't. Heck, I don't even have my graphics card yet. And I will need to upgrade my monitor after I get the graphics card. xD
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2538583
If u just got the 840 pro don't get the 850 pro. The 850 pro is just hands down better all around though.
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2538586
Newer NAND, prettier, and maybe a bit longer lasting.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2538594
Tell me in what ways, not just that it's better.
As I said it better all around. This is true as literally in every single way it is a better drive.
You really don't however there are advantages to the new 850 evo. They are as follows
1. The 850 uses 3d v-nand
2. Longer life span due to the use of 3d nand
3. Minimal speed increase at a reduced power consumption
Hope this helps :)
There isn't a 850 EVO...
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2538714
Marginally faster read and write times, much better longevity, and I believe Samsung finally added RAID support to its 850 SSDs which isn't on the 840 pro series.
Software Engineer for Suncorp (Australia), Computer Tech Enthusiast, Miami University Graduate, Nerd
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2543888
RAID? that a sata controller thing not SSD. If you mean RAPID the 840 Pro got it about two months after the EVO
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2544229
No no no, there's actually a well-known Samsung "bug" where it will write several blocks when the data is split up instead of intelligently writing it to 1 or 2, which of course reduces the life-expectancy of the drive, and it was true of the 830/40 line but I have yet to hear if the 850 Pro line fixed it or not.
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2546314
That would be controller based and the 850 Pro uses the same one as the 840 EVO just souped up a bit. So I dont know I never heard of that issue.
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2552208
He probobly made that up, just like pretty much  everything else he says around these threads. Unless a source explaining it in depth is provided.
RAID doesn't care what device it is on. It can be a potato or a state of the art SSD.
+°´°+,¸¸,+°´°~ Glorious PC master gaming race :wub: ~°´°+,¸¸,+°´°+
BigBox: Asus P8Z77-V, 3570k, 8GB Ram, Intel 180GB & Sammy 750GB, HD4000, W7
PiBox: Rasberry Pi, BCM @ 1225Mhz ^_^ , 256MB Ram, 16GB Storage, pIO, Raspbian
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2555245
Again with your BS.
http://www.tomshardware.com/answers/id-1844707/raid-samsung-pro-840-trim-support.html
There's also the issue of caching not functioning correctly on RAIDed Samsung SSDs.
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2563084
You mean trim? In raid 0 all it need a is a 7 series chiset or newer and intel rst ver 11 or newer. That not samsung specific either.
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2563105
Trim is just the tip of the iceberg, and no, ADATA for instance has it supported in RAID. Internal caching disappears with RAID activated as well. Read on it gets nasty.
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2563946
What kind of internal caching ? :mellow:
SSD does not, i repeat, does not know whether is in raid or not. Its possible, that raiding doesn't play well with Samsung turbowrite cache. Still a link discribing such issues wouldn't hurt.
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2569331
As in the 512MB of SRAM cache shuts off if the drive is thrown into RAID. As per links, they've been provided and are only a google search away. I'm on vacation in virginia so my access is spotty right now (screw Cape Charles) but this is a well-documented issue.
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2597272
First off its not SRAM (512MB of sram would be hella EXPENSIVE) and secondly, SSD cannot, i repeat CANNOT work without DRAM cache if its designed to do so (where would you put redirection tables then ?)
So you're making this stuff up again, beucase you're unwilling to provide sources.
https://linustechtips.com/topic/188540-840-pro-vs-850-pro/#findComment-2597667
