Cine will load every thread. Yeah I see 4.9 in your future, but it all depends on what you're comfortable with.
lol you thread jacker B)
I know, I feel bad for hijacking this guys thread to be honest, but oh well, is there any point in investing in some decent thermal paste to drop a few 'c?
Cpu: i5-2500k @4.8Ghz, MB: Asus Maximus V Formula, CPU cooler: Be quiet! Dark rock pro 2, GPU: Evga Gtx660 FTW@1.24ghz. Ram: Corsair Vengeance 8GB 1866Mhz, PSU: Be quiet! 730w Semi modular, SSD: Corsair force 3 240Gb, HDD: WD Green 1TB, Case: Nzxt H2 with 4 Corsair SP120's, Win7
https://linustechtips.com/topic/18849-2500koc-help/page/2/#findComment-221447
It's more how you apply the paste, not what the paste is made of.
Thinnest layer possible and your cpu/cooler should be perfectly flat. Scratches are ok...that's why we use paste :P
Thanks for all the advise guys, will try it out.
Have fun!
https://linustechtips.com/topic/18849-2500koc-help/page/2/#findComment-221469
You're welcome. Be sure to post your results here, and post any issues that come up along the way so we can be of assistance.
https://linustechtips.com/topic/18849-2500koc-help/page/2/#findComment-221476
Have fun!
Hmmm, we'll see then.
https://linustechtips.com/topic/18849-2500koc-help/page/2/#findComment-221482
What motherboard do you have? I apologize for the delay. I didn't see this post in my notifications for 3 hours.
https://linustechtips.com/topic/18849-2500koc-help/page/2/#findComment-221951
<p>There should be an area for the straight multiplier. I would disable turbo boost. Also, did you disable any power saving options? It may increase stability by disabling them.</p>
https://linustechtips.com/topic/18849-2500koc-help/page/2/#findComment-221974
So i disabled c1e, c3/c6 state and EIST function. Is that alright.
Yup.
https://linustechtips.com/topic/18849-2500koc-help/page/2/#findComment-221990
Alrighty, i will let you know how things went.
Okay. Great.
https://linustechtips.com/topic/18849-2500koc-help/page/2/#findComment-222022
i put in the bios 1.280 volts on the cpu and in windows it says under p95 load its at 1.236v. I had the LLC at medium. Any thoughts?
You probably don't need that high of voltage anyways(1.280 value), but how about trying to get LLC at its maximum?
https://linustechtips.com/topic/18849-2500koc-help/page/2/#findComment-222053
Perfect thanks.
You're welcome.
https://linustechtips.com/topic/18849-2500koc-help/page/2/#findComment-222079
So i got to 4.3 GHZ at a core voltage of 1.272v. I might keep going higher in a while but for now im gonna run this for 24 hours and test how it runs.
Okay. Great. What are your P95 temps so far? Also, try to lower your voltage. I'm running at 4.3GHz now and my voltage is sitting at 1.21 to 1.22. Unless your system becomes unstable at that voltage.
https://linustechtips.com/topic/18849-2500koc-help/page/2/#findComment-222383
Max is 65, lowest is 61, its kinda hot in my room right now but it looks good so far.
Not bad. Especially for a hot room. What are your fan RPMs? Oh and, what's your cooler?
https://linustechtips.com/topic/18849-2500koc-help/page/2/#findComment-222391
I have crappy fans right now, the highest rpm that they can go is 800rpm, so thats what they are running at. And I have a h100i
Are you gonna be replacing those fans at all?
https://linustechtips.com/topic/18849-2500koc-help/page/2/#findComment-222400
