seagate barracuda 2tb
https://linustechtips.com/topic/188230-hdd-help/#findComment-2534068
it stopped at pass 5 0% consolidated
let it run and see if there is any progress
the rate of how it does the de-fragmentation depends on the age and speed of the drive
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/188230-hdd-help/#findComment-2534140
https://linustechtips.com/topic/188230-hdd-help/#findComment-2534142
yes
Try getting something other than that... Defrags don't usually take 24 hours unless it's a really slow, large drive or the drive is nearing the end of its life...
https://linustechtips.com/topic/188230-hdd-help/#findComment-2534232
