option a, i wouldn't buy watercooling parts off ebay
Specs
A. Watercooling parts are a bitch when buying off Ebay. Just like any other PC component, number one rule with Ebay. Always be skeptical.
I´d never buy components on sites like Ebay or Craigslist...
Buy in a approved retail store like NewEgg, FrozenCPU, PerformancePC and you´ll get what you pay for and if something is DOA you can RMA it any time. Water cooling is very sensitive, don´t take any risks.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
If you go option A, you can get a H55 + G10 for only $75 + Shipping. No mail in rebates!
Do your research and be aware that you will need some additional VRM cooling if you go G10.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
If you want to watercool, do it the proper way with parts from performancepc's/ frozen CPU etc.  DO NOT cheap out on things unless you have recommendations from someone that has used the same parts without issue.
If you don't have the money to do a custom loop with good quality parts, I'd recommend a g10 + aio + another aio for the CPU.
