C# Help ?
Go to solution Solved by yuh25,
Looks like you're using visual basic, by the looks of it, just from the .vb
and you'll also have to have:
using System.Windows.Forms;
at the start of the program I'm pretty sure.
I am trying C#, not going too well, i cant even get variables to work
I know it's not meant to look like this, i am messing around to attempt to fix it
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/187829-c-help/
Just take any online C# tutorial to get past basics. There is not much help to offer here.
Don't know C# but imho it should be something like:
string name;name = "Ross";MessageBox.Show(name);
Nope, not working
https://linustechtips.com/topic/187829-c-help/#findComment-2528508
3700x, Asus B450i, 16GB Corsair Vengeance RGB, Gigabyte GTX 970 ITXDan A4-SFX, SX600-G, 120mm AIO.
https://linustechtips.com/topic/187829-c-help/#findComment-2528522
What ?
Well now i feel like an idiot
https://linustechtips.com/topic/187829-c-help/#findComment-2528525
