So when my computer boots it says it shows that the time is not set properly and such and I can reset my bios or do nothing and continue and my time will not be saved and continue counting only when my PC is on..
For example I set it off at 20:00
and when I restart my PC the next day it starts at 20:01 and goes on.
My Cmos battery is more than four years old right now so that basically means I have to replace it, rightt?
I did already take it out and put it back in but that didn't result in anything different.
https://linustechtips.com/topic/187404-a-small-question/
Replace it and see what happens. You can go into the BIOS/UEFI and play around with the time.
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
https://linustechtips.com/topic/187404-a-small-question/#findComment-2521509
Sure sounds like the Cmos battery needing a replacement.
Replace it and that should fix it.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/187404-a-small-question/#findComment-2521510
There's also a wierd thing where my keyboard suddenly doesn't work in the BIOS so I have to unplug my keyboard each time before booting up my PC.
I guess I'll buy a new battery with similar specifications.
https://linustechtips.com/topic/187404-a-small-question/#findComment-2521516
Yep.
https://linustechtips.com/topic/187404-a-small-question/#findComment-2521520
Yeah, 100% just a dead CMOS, hence you can't save the time. A new CR2032 is like, $2-$6 depending where you go.
Fun fact: the CR2032 is used in a lot of things besides the CMOS, from watches, to key FOBs.
"Any sufficiently advanced technology is indistinguishable from magic" - Arthur C. Clarke
Just because it may seem like magic, I'm not a wizard, just a nerd. I am fallible.
Use the quote button or @<username> to reply to people | Mark solved troubleshooting topics as such, selecting the correct answer, and follow them to get replies!
Community Standards | Guides & Tutorials Troubleshooting Section
https://linustechtips.com/topic/187404-a-small-question/#findComment-2523952
