Hi,
..i'm looking for two rigs as from intel side such as amd. I like this case i'vee seen today coolermaster elite 130. im looking to build in this case but if u know a better1 pls let me know. {*As for cpu, my self, i would be fine with a i3 4330, as from amd im not sure. i want no oc at all. As for GC i have no idea wat fits in that case, a good 'cheap' gc nvidia or radeon.*} I dnt need a dvd and a hd bigger than 500gb, just psu ssd, cpu, gc, ram, mb. Please dnt ask the budget or do an overkill build. I want some ideas and toughts.
https://linustechtips.com/topic/187129-mini-itx-build/
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/187129-mini-itx-build/#findComment-2517822
According to the cooler master website:
  • Supports ultra high-end graphics card up to 343mm / 13.5 inch, such as AMD HD7990 and NVIDIA GTX690
Basically, all current dual-slot gaming GPUs would fit.
A great GPU for a budget is the R9 270 or R9 270X
https://linustechtips.com/topic/187129-mini-itx-build/#findComment-2517825
Depending on your budget, 130 is great for the budget, but the 250D is like $100 and is nice too.
What is your budget? WHere do you live?
Good GPU would be 270/280, but we would need your budget to determine that
just go for it, lets say an i5 non k is overkill for my needs, i want your ideas. do it from newegg. i need ideas then we can cut off or add.
https://linustechtips.com/topic/187129-mini-itx-build/#findComment-2517829
https://linustechtips.com/topic/187129-mini-itx-build/#findComment-2517851
good build, except the R9 270 is better at the same price.
Yeah, i wanted to make the couples AMD -> AMD and Intel -> Nvidia, maybe the GTX760 would be a better choice but remember that costs sth more...
https://linustechtips.com/topic/187129-mini-itx-build/#findComment-2517861
Oh, as for the cpu cooler was only a suggestion, but now, thinking better of it, if you don't absolutely overclock you should be fine with the stock ones ^^
As for the storage, if you already have enough space is higly recommended that you buy an ssd, would help if you want fast storage (a tip, go for the 840 pro or evo...), if you want an hdd, the fastest is the caviar black, from WD, really noisy and kinda hot, is better (and a bit cheaper) the barracuda xD
Hope this helped,
EMENCII
https://linustechtips.com/topic/187129-mini-itx-build/#findComment-2517904
oke, $550-$600, i want an ssd 128gb, 250gb or 500gb MAX gb HD. i don't need a dvd, still try and stick to a i3 4330 as a cpu. no cpu cooler as well if i rly rly rly dont need it with this cpu.
https://linustechtips.com/topic/187129-mini-itx-build/#findComment-2517906
Buying a 250 gb hdd is a waste of time searching for it, dunno if they are produced anymore... If you dont need an hdd, go for a larger ssd...
https://linustechtips.com/topic/187129-mini-itx-build/#findComment-2517935
https://linustechtips.com/topic/187129-mini-itx-build/#findComment-2517945
Not clear on usage or what level of gpu is desired so I picked the GTX 750 Ti as a nice entry level gamer.
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor ($114.99 @ NCIX US)
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard ($95.99 @ Amazon)
Memory: Team Vulcan 8GB (2 x 4GB) DDR3-1600 Memory ($68.99 @ Newegg)
Storage: Kingston SSDNow V300 Series 240GB 2.5" Solid State Drive ($95.98 @ Newegg)
Video Card: Zotac GeForce GTX 750 Ti 2GB Video Card ($134.99 @ Amazon)
Case: Cooler Master Elite 130 Mini ITX Tower Case ($42.99 @ Mwave)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($54.99 @ Newegg)
Total: $608.92
Generated by PCPartPicker 2014-07-26 15:33 EDT-0400
CPU: AMD Athlon X4 760K 3.8GHz Quad-Core Processor ($89.99 @ Newegg)
Motherboard: ASRock FM2A88X-ITX+ Mini ITX FM2+ Motherboard ($98.99 @ Newegg)
Case: Cooler Master Elite 130 Mini ITX Tower Case ($49.99 @ Newegg)
Total: $575.92
Generated by PCPartPicker 2014-07-26 15:36 EDT-0400
https://linustechtips.com/topic/187129-mini-itx-build/#findComment-2518062
