Disabled C1E?
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/187016-cpu-clock-speed/#findComment-2516280
It doesn't affect performance you know :P
If the CPU doesn't need to run at its max clockspeed then it may aswell knock down to 1.6GHz or so
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/187016-cpu-clock-speed/#findComment-2516334
Disabled the EPU?
Altered the CPU Fixed Frequency?
Take note - if your OC is stable you should be able to leave that stuff on tbh. Only if you're overclocking to the extreme should it all be off.
https://linustechtips.com/topic/187016-cpu-clock-speed/#findComment-2516338
Disabled the EPU?
Well it seems pretty stable and temps never go above 80 degrees so i will just leave it..
https://linustechtips.com/topic/187016-cpu-clock-speed/#findComment-2516360
