This past week I built my gaming rig and I'm a bit uneasy about my CPU temps.  It's an i7 4790K cooled by a Cooler Master Hyper 212 Evo.  It idles around 35C, under gaming load it runs around 65-75C and when running Prime95 it goes to around 90C.  Is this normal with a CM Hyper 212 Evo and this CPU?
\\\Trogdor...the...Burninator...///
CPU: AMD Ryzen 9 3950X CPU Cooler: Noctua NH-D15 Chromax Black MotherBoard: Gigabyte X570 Aorus Master RAM: 32 GB G.Skill Trident Z Neo DDR4 3600 MHz Storage: Samsung 950 Pro 256GB (OS) + Samsung 850 EVO 500GB (Games) + Samsung 860 EVO 500 GB (Scratch) + WD Blue 1TB 7200RPM (Data) + WD Black 6TB 7200 RPM (Videos) Graphics Card: Nvidia GeForce GTX 1080 Founder's Edition Case: Corsair 760T Power Supply: Cooler Master V850 Operating System: Windows 10 Pro 64bit + Manjaro GNOME KeyBoard: KBD19X (BOX Navy) Mouse: Corsair M65 Pro RGB Monitor: Dell S2719DGF
https://linustechtips.com/topic/186895-i7-4790k-temps/
Completely normal if your ambient temperatures are around 23 to 25C.
Prime 95 is an unrealistic load. You can treat that as a worst case scenario.
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
https://linustechtips.com/topic/186895-i7-4790k-temps/#findComment-2514894
Okay, thanks!
https://linustechtips.com/topic/186895-i7-4790k-temps/#findComment-2514933
Those temps sound about right, the idle might be a bit high but the motherboard is probably just got the fan turned down when the temps are low because there is no benefit to running the fan @100% when it can run it low and slow and keep the PC quiet well maintaining acceptable temps I wouldn't really worry about the chip getting too hot unless you're pushing over 100C under prime and over 90C in games then there is something that is going on like poor airflow, mounting, thermal paste, exc.
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
https://linustechtips.com/topic/186895-i7-4790k-temps/#findComment-2514951
Its fine. Also use IETU instead of prime 95 for stress testing.
https://linustechtips.com/topic/186895-i7-4790k-temps/#findComment-2514972
Prime95 the absolute worst case scenario and you are still a fair distance away from TJMax during Prime95 so you can safely say that you are fine. Still though going from 35 idle to 70 under load seems a bit unrealistic. My I5-2400 goes from 45 idle to 55-60 under load on the stock cooler and I would expect to see better with a 212.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/186895-i7-4790k-temps/#findComment-2518366
It could be the thermal paste that ships with the CM 212 Evo.  It looked a bit like grey rubber cement.  If this is the case then maybe I'll go with some Arctic Silver MX4.
https://linustechtips.com/topic/186895-i7-4790k-temps/#findComment-2527889
