|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
https://linustechtips.com/topic/186527-best-cooling-solution/#findComment-2509350
dark rock pro 3 for aesthetics (and decent performance)
nh-d15 for unbeatable performance (but slightly less, but acceptable aesthetics)
Home is where the heart my desktop is.
https://linustechtips.com/topic/186527-best-cooling-solution/#findComment-2509385
D15.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/186527-best-cooling-solution/#findComment-2509476
D15 it is, guys. Just wondering, how would a D15 compare to a water cooler of the same price?
It's almost on par with the performance of the 240mm Corsair H100i and quieter. The Corsair has about a 2 degrees Celsius lower DeltaT.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/186527-best-cooling-solution/#findComment-2509860
Its very close to $160 water coolers
|| MAELSTROM ||
https://linustechtips.com/topic/186527-best-cooling-solution/#findComment-2514810
