Chassis + Fans & Setup
Solved by WhatTheQuack,
Hehe, possibly.. they have been under quite some stress those 4 years haha. Green LEDS though, nothing special i suppose... though its extra extra:). NOAICE, my closet saved me. Best way to clean them correctly though? They probably have a big lé plaque of dust on them lol. Normally you would say air or just rub it off... anything specific though, perhaps to up some of its performance for re-usage
It is possible to change the lubricant on the bearings, but that is difficult so I wouldn't recommend it on cheap fans. Otherwise, A quick blast of some canned air or a dust off with a damp cloth will be just fine
