Okay guys, so this is my first post. Basically I just built a new budget gaming rig. The specs are here: http://pcpartpicker.com/p/WD2Z99
Basically I was told that this motherboard can overclock my CPU. The video I basically formed the build around can be found here:
I've tried using Intel XTU, but I'm not sure if I'm using it right, I've also tried overclocking in my MSI bios version 6.5, however the cpu multiplier won't go past 32 even though I'm using the Intel Pentium "K" (G3258)
If someone could give me an explanation I'd appreciate it. This board has OC Genie 4 so it has to have some overclocking of the cpu some how right? I also have no extra money because I'm a college student working 2 jobs, so buying a z97 board is out of the question. Any help would be greatly appriciated.
Also, here's a link to a YouTube help video I made:https://www.youtube.com/watch?v=eNSfxsIgKRw&list=UU4LGWtJpze5uF4BW9uI86Jw
https://linustechtips.com/topic/185943-problem-overclocking-on-new-rig/
another user have this same problem
revert back to stock settings and enable TurboBoost function
and start increasing the multiplier on stock voltage
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Also, could you link that thread?
http://linustechtips.com/main/topic/185340-trouble-overclocking-g3258/
How do I enable TurboBoost in my bios?
reading the manual now
ok according to the manual
the TurboBoost function is in the OC section in the UEFI
I dont think your board will allow you to OC that cute little pentium.
officially H81 chipsets do not support Overclocking.
you also do not have any cpu voltage options in your bios.
can you post a full screenshot of xtu "all controls" tab.
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
http://imgur.com/GHjej14
well you might be in luck because xtu shows your multi unlocked.
you still have no voltage options
slide these all the way to the right and hit apply
turbo boost power max
processor current limit
turbo boost short power max
turbo boost power time window
select 32xmulti on both cores
click blue wrench on lower right side. select cpu core voltage
run cinebench r15 and watch your voltage
next increase multi to 33x. run cinebench r15 again and watch your voltage
keep increasing multiplier followed by a cinebench for a quick test.hopefully the "auto" voltage rule increases your core voltage.
confirm frequency and voltage with cpuz and xtu
If I stream at http://www.twitch.tv/turtlemcgee/ can you help me OC in realtime please?
The article about the MSI H81 overclocking in that video description is ancient and would have been patched in a microcode update a long time ago. Not a very well informed video.
Only relevant thing would be ASUS H81 boards but it's only a matter of time before Intel block that with a microcode too.
  • 4 weeks later...
These people are lying to you. Do not listen to them they have no idea what they are talking about
If you don't own his MoBo and CPU you probably shouldnt be commenting on this post trying to tell him that he cannot overclock.
Head over to my forum, I figured out the solution to this in a couple hours of fiddling with things. The solution is posted there:
http://linustechtips.com/main/topic/200223-overclocking-g3258-help/#entry2714271
