I am doing a custom water loop and have sli 780 ti's.
http://www.frozencpu.com/products/23687/ex-blc-1696/EK_GeForce_780_GTX_Ti_DCII_VGA_Liquid_Cooling_Block_-_Acetal_Nickel_EK-FC780_GTX_Ti_DCII_-_AcetalNickel.html
this is the water block i am using on both cards. What is the best way to connect the 2 sli cards without using tubing.
thanks
https://linustechtips.com/topic/185915-sli-water-cooling/
telescoping fittings or a solid SLI watercooling bridge
https://linustechtips.com/topic/185915-sli-water-cooling/#findComment-2500195
XLOEXS ICase Corsair® Obsidian 250D | CPU Intel® Core™ i7 4790K | GPU NVIDIA® GeForce™ GTX TITAN Black 6GB | Motherboard Asus Z97i-Plus | Memory 16GB Corsair® Dominator™ Platinum DDR3-2133 (2x8GB) | HDD 3TB Seagate® Barracuda™ XT | SSD 500GB Samsung® 840 EVO SSD | Cooling Swiftech Apogee Drive II CPU block/Pump Combo, Hardware Labs Black Ice Nemesis GTS 240 + EKWB XTC CoolStream 140 Radiators, NoiseBlocker Black Silent Pro PLS 120mm X 2 + Corsair AF-140 Fans, Koolance TNK-501 Single 5.25in Bay Reservoir, Rev.1.1, Primochill Advance LRT Flexible PVC Tubing, Mayhems Pastel Mint Green Coolant | PSU Corsair® Professional Digital Series AX860 80+ Platinum Certified Modular Power Supply.
https://linustechtips.com/topic/185915-sli-water-cooling/#findComment-2501136
thanks
One of these, parallel or serial, doesn't matter which because the difference in performance is negligible.
#1: http://www.frozencpu.com/products/19897/ex-blc-1450/EK_Terminal_Block_-_Dual_Parallel_3-Slot_-_Black_Acetal_EK-FC_Terminal_DUAL_Parallel_3-Slot.html#blank
#2: http://www.frozencpu.com/products/16400/ex-tub-1318/Bitspower_Adjustable_Aqua_Link_Pipe_II_41-69mm_-_Black_Sparkle_BP-BSDG14AALPII.html
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/185915-sli-water-cooling/#findComment-2502331
