Fan Controller Help Needed!
Go to solution Solved by kd1011,
3 pins: Regular DC fan, can either be run at a set speed, or some motherboards (e.g ASUS) can control them by changing the voltage.
4 pins: PWM fans, all fans receive the full 12V and a separate signal is used to set speed. If your fan controller or motherboard has 4 pin headers, PWM fans are a better choice, as you can set things like fan curves.
For fan controllers, NZXT has a new software one out (I think it's called grid+), and corsair are apparently working on a new link software module.
NB: the NZXT one only supports 3 pin fans
EDIT: Looks like your mobo is similar to the VII Formula I'm getting, you have 3 4pin PWM headers on the mobo. Each header supports 12W, so using splitters, you could have software control basically for free, with 3 zones of control.
You could also get the ROG front base, for manual control of the mobo headers.
I have a total of 8 fans in my corsair 900D, the 4 stock fans plus 4 af-120's on my 480 rad.
I have an Asus rampage Iv extreme black edition mobo.
I would like to be able to control all 8 fans and possibly take some temperature readings? I would settle for a 6 channel fan controller but I would prefer 8.
My budget is under £50 ($85) I would also prefer a black or metal finish on the fan controller. The fan controller must be available in the UK!
Also if someone could explain fan connections (3/4 pin, PWM?) as it is the only aspect of my PC I don't fully understand =D
This community is ace, I only have a few topics but I've received absolutely amazing help and I'm sure I'll get the same great experience on this one :)
Many thanks,
Relwof
https://linustechtips.com/topic/185759-fan-controller-help-needed/
Phanteks has a fan hub that lets you connect up to 11 fans while only taking a single 4 pin connector on your motherboard. You can then control them through software.
That's the one I'm currently using as it came with my case. I don't quite understand the technicality of 3/4 pins but all I know is that you cannot control 3 pin fans connected directly to your motherboard while you can with 4 pin PWM fans (pulse-width modulation). Since the hub uses a 4 pin connector, you can control your fans that way. Note that all fans are going to be considered as one, since the motherboard recognizes only 1 fan (the hub) plugged in. Fan speed will be the same for all.
Hopefully it's available in the UK :) If you want individually controlled fans, you'll have to look at more expensive solutions
CPU: Intel i7-4770k MOBO: Asus Maximus VI Formula RAM: G.Skill RipJawsX 2x8GB 1600Mhz GPU: Asus GTX 780 DCuII CASE: Phanteks Enthoo Primo STORAGE: ADATA SX900 256GB / WD Caviar Blue 1TB PSU: Corsair AX760 760W MONITOR: Dell Ultrasharp U2312HM KEYBOARD: Ducky Shine 3 MOUSE: Logitech G602 http://linustechtips.com/main/topic/106614-project-insert-name-enthoo-primo-rigid-acrylic-red/
Thanks! I'll have a look at that tonight, although I would like to be able to control some fans individually. Thanks a bunch :)
Have a look at the Lamptron FC5 v3, hopefully it's available in the UK.
Some modern motherboards can control both 3-pin and 4-pin PWM fans through the motherboard fan headers. 3-pin being voltage controlled and 4-pin fan through Pulse Width Modulation. 4-pin PWM fans have the advantage because they can be controlled more precisely and smoothly without annoying harsh ramp ups or downs. You can plug 3-pin fans in 4-pin fan headers. 3-pin fans are cheaper tho and I recommend you use those with a fan controller as it would be waste to buy PWM fans and voltage control them.
Bert & Ernie before squirting spermie.
