I need some help installing teamspeak3 on Linux
Go to solution Solved by UselessBread,
Now that I've done that how to I open it
You will have a folder that looks something like this:
Yours will probably not be called that though as you are using 32bit.
The ts3client_runscript.sh will run the teamspeak client. I can't remember if it was executable, but you should just be able to double click it.
If you want you can move the folder to a better location and create a symbolic link to it. I don't know though what the best place to move it would be, or how to get ubuntu to show it in the applications thing.
So I blew my power supply in my main rig so I grabbed my old Linux Server Out of the closest and am using it as my desktop I am currently running 13.10 32bit, I just don't know how to install this .run file for teamspeak and can't seem to find anything on line that tells me how to do it, I am sort of a windows junky so I don't have much experience on Linux at all.
Thanks,
Brad
 Forgot to mention I am trying to install the client
Edited by bamerx98
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
teamspeak server or client?
Client
What Linux distro are you using? Ubuntu, Debian, Opensuse etc
Wraith/Main Rig: AMD Ryzen 7 5800X3D | DeepCool AK620 | ASRock X570 Steel Legend | Micron Workstation ECC 64GB | XFX Speedster SWFT 319 Radeon RX 6800 XT 16GB | Topping D50s+A50s+PA3s | Seagate FireCuda 520 NVMe 500GB, Samsung 860 EVO M.2 1TB, Samsung 970 EVO Plus NVMe 2TB, HPE SSD 1.92TB, Toshiba X300 4TB, Seagate SkyHawk 4TB, WD Blue 4TB, HPE HDD 8TB | LG GGW-H20L Bluray-RW, Pioneer DVR-220LBK DVD-RW | HP NC550SFP 10GbE | Super Flower Leadex II Gold 750W | CoolerMaster MasterCase MC500P - Ghost/Test Rig: AMD Ryzen 7 1800X | Scythe Mugen 5 Rev.B | Asus ROG Strix X370-F | Crucial Ballistix Red 16GB | ASRock Intel ARC A770 Phantom Gaming D 8GB | Asus Xonar D2X | Crucial MX500 250GB, Seagate BarraCuda 500GB | SAMA Forza 750W Gold | Antec GX200
Phantom/Win98 Rig: AMD Athlon XP-M 2500+ | Arctic Cooling Copper Silent 3 | ASRock K7S41GX | Elixir 512MB | ATI Radeon 9800 XT 256MB with ATI Silencer 3 Rev.2 | Aureal BA88DL30A-01 Vortex 2 | Seagate Barracuda 160GB | LiteOn IHDP118-18 DVD-Rom | Samsung FDD | Ccivo 300W | CiT S008B - Parvati IV/Home Unraid Rig: Dual AMD Opteron 4184 | 2x Noctua NH-U12DO A3 | Supermicro Aplus H8DCL-i | Samsung ECC 32GB | Matrox G200eW 16MB | Kioxia Exceria G2 1TB, HPE Seagate Exos 4TB, 2x Seagate Barracuda Green 2TB, 2x Toshiba E300 2TB, Seagate SkyHawk 2TB, 2x Samsung Spinpoint F4EG 2TB, Seagate Essentials 1TB, WD Green 500GB | Dell Perc H200+H310 HBA, HP NC550SFP 10GbE | Cooler Master MWE v2 850W | Corsair Obsidian 750d Full Tower - Behemoth12/Second Unraid Rig: HP Microserver G8 | Xeon E3-1220L V2 | Intel C204 | Hynix ECC 16GB | Matrox G200eH 16MB | WD Green 500GB NVMe |
You need to make the .run file executable. For that navigate to the folder in your terminal and
$ chmod +x tssomething.run.
Then execute the file from terminal.
$ ./tssomething.run
It will create a folder with teamspeak in it. (oh and ask you a bunch of things, I think the license agreement)
Looks like Ubuntu as he said 13.10
^ Ah yes true. :P
$ ./tssomething.run
attachicon.gifScreenshot - 230714 - 06:02:53.png
Thank you so much I finally got it working, its a pain on Linux don't really get why they didn't just make it like other applications but I guess it works so what ever
Well you can find teamspeak 2 in most repositories, I guess it is some decision teamspeak made to not have teamspeak 3 there. No idea why that happened though, it certainly is highly retarded.
