I was going to get a Fractal Design Define R4 but after seeing a few vids, it looks quite "stuffy". This is going to be my first build ever and I really want a good case for a good price. My budget is $120 but I can go a few more bucks (up to 150?). Here's what I want
A window so I can admire my first build lol.
Roomy? Well more room than the R4
Good/Easy cable management
Noob-friendly
Good airflow.
Thanks!
https://linustechtips.com/topic/184260-mid-tower-atx-case/
https://linustechtips.com/topic/184260-mid-tower-atx-case/#findComment-2476008
AIR 540 hands down for those needs. Everything you want, the AIR 540 has.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/184260-mid-tower-atx-case/#findComment-2476009
Tha HAF X is the first that pops to mind specially the nVidia edition, really man, Verry Roomy, Verry Good looking, Verry Good airflow, Verry good and easy cable Management
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/184260-mid-tower-atx-case/#findComment-2476025
I have an arc midi R2 which is basically the same internal design as the define R4 but with a bit more airflow
tweak_dk_Fractal_Design_Arc_Midi_R2_5.JP
Though I am getting a bit bored with the case and prolly going to repurpose it and get one of these
The only thing I really do not like about it is those ugly blue LEDs and drive sleds.  Easy fix to that though as all of them are removable and you can attach up to 2 drives (3.5 or 2.5) kinda hiddenish on the side.  Air flow?  no problem,  2 200mm fans up front one up top and a 140 in the rear.  Im going to replace them with bitfenix spectre pro's though red LED 2 up front 2 in the top and 140 in the rear and 2 120s in the bottom.  Top and rear at 7v.  It will be the king of air flow heh.
https://linustechtips.com/topic/184260-mid-tower-atx-case/#findComment-2476026
