PC Processor upgrade
Go to solution Solved by i_build_nanosuits,
for gaming pick an intel cpu they perform better, if you cant afford those unlocked ''k'' cpu, look for an i5-4460 with an h97 motherboard since this is still better than amd for gaming and cost about the same!
In a few days i will be 17 and so i decided to upgrade my processor. I am thinking about buying the i5 4670k with a suitable motherboard.
Is this a good choice or do i go for an AMD equivalent???
Please Help...
PS: My PC is purely used for gaming. :)
Indus Monk = Indian+ Buddhist
https://linustechtips.com/topic/184029-pc-processor-upgrade/
I second what @GingerbreadPK said, however please say what cpu you have now so we can tell you if it's a worthy investment or if you should wait/keep what you have. If you have a second or third generation i5 cpu it makes no sense to upgrade.
sudo chmod -R 000 /*
https://linustechtips.com/topic/184029-pc-processor-upgrade/#findComment-2473014
the question remains..... do i go for 4670k or an AMD equivalent???
At the moment Intel makes the better CPU's. Especially in terms of heat output. AMD if you can't afford Intel. 4670K/4690K with a Z87 or Z97 motherboard respectively.
P.S: don't forget to quote, even if you're following the topic others won't know if you replied unless their following the topic too.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/184029-pc-processor-upgrade/#findComment-2473651
if i had to go for AMD then which AMD processor do i choose??
https://linustechtips.com/topic/184029-pc-processor-upgrade/#findComment-2473733
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/184029-pc-processor-upgrade/#findComment-2473890
