hi all !
i just installed a i5 3570 into my living room PC. i ran a game of bf3 to see what temps i get on a stock cooler.
(using HWmonitor) on the package temps i got 90c.. idk if thats a good temp for a stock cooler lol
stock fan is installed corrected. i used artic silver thermal paste. got rid of the intels stock paste.. so
idk if i should be seeing high temps like that. or is ivy bridge just hot
https://linustechtips.com/topic/183824-i5-3570-temps/
That is definitely not normal. You should be getting 55-65C on gaming load with the stock cooler.(unless you have an ambient of 45C lol)
Re-seat your cooler.This stupid plastic notches tend to break easily causing the heatsink not to kame good contact with the cpu
 i5 3570k @4.all over the place || CM Hyper TX3 Evo || ASRock Z77 professional-m || 8GB G.SKILL Ripjaws Z 2400mhz CL10 || MSI GTX770 2GB OC'd 1280/3825mhz || ADATA SP900 128GB || Fractal Design Arc Mini R2 || Logitech G502 || Audio Technica ATH-M50
A spy is always better than a ninja!See burn notice. EVERYTHING is just a number!
https://linustechtips.com/topic/183824-i5-3570-temps/#findComment-2472748
