The black one?
| CPU: An abacus | Motherboard: Tin foil | RAM: 2 Popsicle sticks | GPU: Virtual Boy | Case: Cardboard box | Storage: Cardboard | PSU: 3... Er... Make that 2 hamsters | Display(s): Broken glass | Cooling: Brawndo | Keyboard: More cardboard | Mouse: Jerry | Sound: 2 Cans of SpaghettiO's |
https://linustechtips.com/topic/183733-phanteks-cpu-cooler/#findComment-2469481
The Phanteks PH-TC14PE is a great CPU cooler, it's a tiny bit better than the Noctua NH-D14
It's not considering the noise vs the D14
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/183733-phanteks-cpu-cooler/#findComment-2471495
  • 2 weeks later...
It consistently performs better at COOLING than the D14. Aestically, with the color options for the phanteks cpu coolers, it certainly LOOKS better out of the box.
If the noise levels are the primary criteria for choosing a CPU cooler, then yes, the Nocuta D14 is going to be quieter.
https://linustechtips.com/topic/183733-phanteks-cpu-cooler/#findComment-2551545
+1 to the TC14PE_BK
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
https://linustechtips.com/topic/183733-phanteks-cpu-cooler/#findComment-2552033
well if you want to match your case with your cooler then this http://www.newegg.com/global/au/Product/Product.aspx?Item=N82E16835709018&cm_re=Phanteks-_-35-709-018-_-Product is expencive but a good cooler if you are on close-loop liquid cooling then go for a NZXT cooler or a Corsair cooler
https://linustechtips.com/topic/183733-phanteks-cpu-cooler/#findComment-2552042
