cooling fan help
Solved by Shaqo_Wyn,
http://pcpartpicker.com/user/Tanst1395/saved/VBWBD3 Im building this and the only thing i have no idea about is fans(to replace the case fans). What i want is something that works very efficiently but is moderately quiet as in doesn't sound like a 747 colors would be nice(black, green, or grey) as my build is razor/asus themed so no ugly noctua for me. Also any other constructive criticism is appreciated except downgrades unless absolutely needed.
Noiseblocker Black Silent Pro's. Noctua IPPC's. Silverstone Air Penetrators. Is this a serious build? It feels like you just grabbed the most expensive components out there in some cases
. What will you be using this for?
