Thermal compound
Go to solution Solved by iNarcissist,
Great that it all went well for ya, mark the topic as solved if theres nothing more you want help with?
Im going to be using this Antec Formula 7 Nano Diamond,no idea where I got it.
Anyways ill be mounting a Zalman 9900 onto an i3-4130, so this stuff should be good enough?
also, how much of a temp difference do you think ill see over the stock heatsink/fan?
Thanks
Ryzen 7 5800X3D , Arctic Liquid Freezer  III , Gigabyte X570 Aorus Elite , Corsair Vengeance 32GB , Gigabyte RTX 5070Ti ,  WD SN850 / MP44L
Corsair RM 850x, LIAN LI Lancool 207
https://linustechtips.com/topic/183073-thermal-compound/
it will be fine
and it should run cooler
Not sure what else to say :P
https://linustechtips.com/topic/183073-thermal-compound/#findComment-2460444
A little tip for applying thermal paste. Put about a pea size zed drop on the cpu then take a piece of scotch tape and put the sticky side on your finger then use that tape to spread the thermal paster all over the cpu in a thin layer.
https://linustechtips.com/topic/183073-thermal-compound/#findComment-2460543
I was expecting better results than the stock, but it about a 20deg difference!! very cool
https://linustechtips.com/topic/183073-thermal-compound/#findComment-2462294
That's actually not very surprising, most of aftermarket CPU coolers out there are better than Intel's stock one, especially in terms of mounting.
Any unknown button should be pressed even number of times.
https://linustechtips.com/topic/183073-thermal-compound/#findComment-2462305
Never spread thermal paste. Are you doolallytat, sir?!
What do they know of England, who only England know?
"Well that's what I always said I wanted to be remembered for, for being honest. Nothing else is worth a damn"
https://linustechtips.com/topic/183073-thermal-compound/#findComment-2462357
If you spread it you are 100% sure it gets all over the cpu and you don't have to worry about air bubbles.
You cause airbubbles by spreading it. The cores are in the centre of the CPU, a small pea size dot in the middle is enough, the pressure of the heatsink will evenly distribute the paste over the CPU, giving a perfect and even layer.
https://linustechtips.com/topic/183073-thermal-compound/#findComment-2463346
No you don't its impossible to cause air bubbles by spreading it and if you do spread it then you are 100% sure it give you a perfect layer all over the cpu. If you put the heatsink on you don't know if it gets all over the cpu.
https://linustechtips.com/topic/183073-thermal-compound/#findComment-2463372
Oh really?
https://www.youtube.com/watch?v=-hNgFNH7zhQ
All using the same method of a dot. And Linus shows the same in his build guides.
https://linustechtips.com/topic/183073-thermal-compound/#findComment-2463400
