Display problems
Solved by dandu3,
Well it says it does, but i tried it once and the display didn't showed up, but i might give it another try.
You need to remove the GPU for it to work, or use the BIOS to change it.
Is your motherboard an APU one by any chance?
octester ·
Posted in Troubleshooting1 -
DavidPatrascu ·
Posted in General Discussion5 -
1
2
bill well ·
Posted in Peripherals0 -
4
2
Ha-Satan ·
Posted in Networking3 -
1
Beenlucky1 ·
Posted in Cooling4
play_circle_filled
Latest From ShortCircuit:
