Hello guys, I got a question about the NZXT H440 case, I just bought it and installed all my hardware inside, all good but, isnt the Logo on the bottom of the case supposed to be turned on all the time?
Because that logo only turns on when I click in the button on the back of the case which is to light up the I/O shield of the motherboard and the PCI-E slots.
If anyone knows or has the same case please help me :)
Thanks in advance.
https://linustechtips.com/topic/182519-nzxt-h440-question/
it's working as intended.
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
https://linustechtips.com/topic/182519-nzxt-h440-question/#findComment-2452530
Oh ok. thanks for the fast responses guys, much appreciated! ;)
Good choice in case :). What colour did you get?
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/182519-nzxt-h440-question/#findComment-2452680
