Razer Deathadder Mousepad Solution?
Go to solution Solved by Enderman,
Too thin? Like material thickness? The Corsair MM200 Compact edition is not very this and great quality material.
I just bought a Razer Deathadder and I want a mouse pad for it. I have been looking at corsair and steelseries mouse pads but don't know which one to get. The standard size mouse pads I fell are too big but the compact and mini ones are too thin. Anyone have a compromise. I also liked the extended ones. Im looking for a mouse pad under 20. Thanks.
https://linustechtips.com/topic/181845-razer-deathadder-mousepad-solution/
just get any soft one, they are all nice.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
The one mouse pad I do recommend is from Razer themselves, The Razer Goliathus is a really nice mouse pad. I personally use the speed version which is very slick and offers very little resistance and there is also a control version which does give the pad more traction for better control of the mouse.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
