Help please quick
Go to solution Solved by Toasted Waffles,
Found the problem. The CPU cooler was on too tight :(
I have a rog Maximus formula V . Installed new CPU cooler and now I am getting a Code "55" already tried to switch ram with brand new ram
Project Casper - Glass Tubing Build
Ryzen 9 5905x     |    Gigabyte Aorus Extreme X570    |   Strix 3090
GSkill 64gb 4000mhz   |    EVGA 1600T psu     |      3x Samsung 980 Pro NVME 1tb Raid 0
  4 x Crucial MX500 2tb raid 0   |    Glass Hard Line Tubing  - EKWB Blocks
https://linustechtips.com/topic/181784-help-please-quick/
is the cpu fan connected? because a system wont boot with no cpu fan
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/181784-help-please-quick/#findComment-2442082
ya it is
https://linustechtips.com/topic/181784-help-please-quick/#findComment-2442108
It can boot but you will need to disable it in the BIOS to stop monitoring th CPU fan
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
https://linustechtips.com/topic/181784-help-please-quick/#findComment-2442109
The Error is apparently due to your RAM,
Enter your BIOS and change the settings to the default. 1600Mhz, if it work increases it to what your MB and RAM support.
https://linustechtips.com/topic/181784-help-please-quick/#findComment-2442114
it never boots that far
https://linustechtips.com/topic/181784-help-please-quick/#findComment-2442122
How did you place your RAM? are they correct?
Can you give your MB and RAM and other specs,
If your MB support MemOK use it, normally a button around RAM that check compatibility.
https://linustechtips.com/topic/181784-help-please-quick/#findComment-2442139
You can also clean your CMOS, then leave your settings as default and download your latest BIOS update.
https://linustechtips.com/topic/181784-help-please-quick/#findComment-2442148
Look it up in our motherboard manual
System Specs - CPU: i7 4770K - RAM: 8GB(2x4GB) Vengeance Pro - Motherboard: Maximus VI Gene - Case: Modded PowerMac G5 - CPU Cooler: H100i - PSU: AX860i - SSD: Samsung 840 Series 120GB and Kingston V300 120GB - HDD: Seagate Barracuda 1TB - Graphics Card: 2x GTX 780 - Case Fans: SP120s and Spectre 140s - Headphones: HD700, Alpha Dog, SE215
Sony A7R w/ Zeiss 55mm F1.8
https://linustechtips.com/topic/181784-help-please-quick/#findComment-2442158
So all you did was change the cooler and then the fault code popped up?
Did you remove the ram? If so, have you triple checked it's seated properly? Have you tried with a single stick?
Yup
https://linustechtips.com/topic/181784-help-please-quick/#findComment-2442497
https://linustechtips.com/topic/181784-help-please-quick/#findComment-2445552
