Power Surge Killed my PC
Solved by BroKenFingers,
Then it must be a errant drive/software issue..start by removing some of your latest added software..ex. Vuse, Skype, uninstall 1 at a time ..rebooting into regular windows and see how you get on. Do you have a ADD-IN hardware NIC or do you use the MB built in NIC...either way disable (pull it out or disable it in the BIOS) and see if your system is stable..just do 1 ONE thing at a time..and reboot after each change..
Featured Topics
lizziemc12 ·
Posted in CPUs, Motherboards, and Memory2 -
1
Valeatis ·
Posted in Power Supplies0 -
1
1
redywox ·
Posted in New Builds and Planning3 -
Mahbub ·
Posted in General Discussion3 -
da na ·
Posted in Photography and Videography2 -
1
2
