This is my first custom made NAS storage unit, it has ALOT of space I know....so I will break it down for you...(I went with 2 Terabytes since they are alot more stable then 3 or 4 TB drives)
Updated:
2 TB - Movies (some are raw (straight from Video Camera)
2 TB - TV Shows
2 TB - Music Files (I have alot of music and it is going to be in 320...)
2 TB - My Backup of My 1 Terabyte Drive
2 TB - Backup of my Other Computers 1 Terabyte Drive
Suggestions are welcome...be nice tho...as it is my first build for custom network storage.
Motherboard: ASRock Z87E-ITX Mini ITX LGA1150 Motherboard  ($134.99 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($89.99 @ Amazon)
Case: Fractal Design Node 304 Mini ITX Tower Case  ($97.98 @ Newegg)
Case Fan: Noctua NF-B9 PWM 37.9 CFM 92mm  Fan  ($23.99 @ Newegg)
Case Fan: Noctua NF-P14 FLX 65.0 CFM 140mm  Fan  ($17.99 @ Amazon)
Total: $1228.40
If you've previously won the build off please pm me so we can get something worked out.
https://linustechtips.com/topic/180942-my-first-nas-system/
What level RAID do you plan on running? Also do you plan on buying an external raid card or using the on board RAID controller on the mother board ?
CPU: Intel I7-4790k | MOBO: Asus Sabertooth Z97 Mark 1 | Ram: Corsair Vengance 32GB 1600hz | GPU: EVGA GTX980 Reference
PSU: Corsair EVGA G2 850W  | SSD: Intel 730 Series 480GB, Kingston SSDNow V300 120GB | HDD: WD Black 1TB
 CPU Cooler: Corsair H105 | Case: Corsair 760T (White) | Peripherals: (2)Asus VS247H-P, Corsair M65, Corsair K70 RGB w/ Brown Switches
https://linustechtips.com/topic/180942-my-first-nas-system/#findComment-2430132
I was thinking of an on-board one unless you have a cheap one in mind....
From my experience , when running Raid, cheap is never a good thing. I am looking at building a home server off of a HP Proliant Gen 8 Micro server in the future, and my RAID card alone is 300 dollars. The cheaper the card you get, or even by using on board RAID, you run the risk of having poor management, performance, and rebuilding tools. A cheaper card is usually more prone to failure and writing errors. Now I am not saying they are all bad, I just have nothing to recommend that is cheap.
https://linustechtips.com/topic/180942-my-first-nas-system/#findComment-2430191
I wasn't actually thinking about running raid on it...Movies and TV Shows...problem solved :) Music, Backup for my Computer, Back up for Fiances computer.
https://linustechtips.com/topic/180942-my-first-nas-system/#findComment-2430197
Alright, just know if a drive fails, you will loose all of its data. So it will be wise to have the information else ware too if it is something important. Also if you wanted to end up running Raid and you wanted 4TB for movies, 2TB for Music, 2TB for PC Backup, 2TB for other PC backup, you will either need larger drives or more drives.
https://linustechtips.com/topic/180942-my-first-nas-system/#findComment-2430213
You make a good point...I am going to have a double backup...Each computer will have there own 2 TB external as well as back up on the server...so it will be double backed up. Movies, TV shows, and Music...its alot of work to redo it all but I've (so far) never had a drive fail....but there is always a first...and it wouldn't be the end of the world for those drives.
https://linustechtips.com/topic/180942-my-first-nas-system/#findComment-2430230
I have had a few drives fail on me, and at work I have had countless server drives fail along with a couple handfuls of workstation hard drives. I like being on the safe side when it comes to mass storage, and have a Raid running on my NAS\file server and have a off site backup done every month in case something happens to my house.
https://linustechtips.com/topic/180942-my-first-nas-system/#findComment-2430237
Unless you know somewhere I can access 2 Terabytes worth of space for free.... lol
https://linustechtips.com/topic/180942-my-first-nas-system/#findComment-2430314
I just get something like WD Red drive, put all my data on there with a USB 3.0 to SATA, transfer the data and take the drive back. My internet speeds are way too slow to upload large amount of files.
While it's not free and not the best method, it gets the job done.
https://linustechtips.com/topic/180942-my-first-nas-system/#findComment-2430339
Hmmm....thats a good idea...however most of my "critical files" are locked in a safe lol....not even on a computer...which case is the best for large amount of storage...and is it possible to use wifi on this?
https://linustechtips.com/topic/180942-my-first-nas-system/#findComment-2430411
Wi-Fi on what?
https://linustechtips.com/topic/180942-my-first-nas-system/#findComment-2432404
