Hello All, I am getting horrible Internet download/ upload speeds, like less than a Megabyte... But my Ookale speedtest gives almost 10 MBps both ways, and a Ping of 30. In the Task Manager it says my Link Speed is 13 MBps (I assume this is based of of my Router speed which is 300 MBps) The PC's WiFi is a Dell 1501 (Can't find the speeds online).
I assume the slow speeds are my Hard Drive being slow. As it is several years (5). The Drives are 7200 RPM, Sata 3Gb/s HDD. (Model is a Dell Inspiron 2305 2.4 Ghz).
Here is the rest of the Specs in my system if needed.
Ram - 6Gb 1333 MHz (Couldn't find brand name for it)
CPU - AMD Athelon II 2.4Ghz
Wireless Card - Dell 1501.
HDD - Sata 3Gb/s 7200 RPM (Lack of Brand Name)
GPU - Radeon HD 5470 1 GB
Windows 7 64 Bit
Any help is appreciated.
Please don't make fun of my Horrible PC D:.
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/180483-wireless-speeds-slow/
Is this 802.11b, 802.11g, 802.11n or 802.11ac?
If it's 5 years old, it's most likely an 802.11n... Your wifi router might be the one causing problems...
https://linustechtips.com/topic/180483-wireless-speeds-slow/#findComment-2424072
Nothing wrong with 802.11n though if your devices don't support 802.11ac. But yeah, if it's old it may be causing problems. @niofalpha try borrowing one from a friend and see what's happening.
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
https://linustechtips.com/topic/180483-wireless-speeds-slow/#findComment-2424100
Windows 7 64 Bit
Bam
Bet that's your problem. Dell 150x wifi cards are terrible and for some reason tend to start working at less than 200KB/s.Nothing to do with drivers or any other factors. They just burn out somehow.
I have had tons of those fail when I worked IT and we had dell latitudes.
I even had to replace it on my personal one.
You can get a good intel used wifi card for ~5$ on ebay.
https://linustechtips.com/topic/180483-wireless-speeds-slow/#findComment-2424294
