Need a cheap cooler
I need a cheap cooler, preferably $20 or lower. I live in Canada.
This is for a LGA775 P4 HT 530 in my really really old Gateway. I do believe it is in mATX format (definitely not BTX), and the socket area is pretty clear of caps and the like. The stock CM cooler is really, really loud and I would like something quiet that is cheap as well to replace that monstrosity.
Please do not suggest a 212 EVO; the 500GR doesn't have a lot of clearance so 120mm towers are probably out of the question (plus the EVO is $30, out of my budget range). Keeping in mind that Prescott runs pretty hot too.
Also, do you think it will be able to run as a HTPC with 2 x 256MB DDR? Im not too familiar with HTPC OSes and I think Win 8 would be quite a stretch for this single core chip.
https://linustechtips.com/topic/179534-need-a-cheap-cooler/
Sycthe samurai zz rev b or shuriken
Thermaltake contac 21
https://linustechtips.com/topic/179534-need-a-cheap-cooler/#findComment-2411959
Win 8 uses a lot of RAM and I have it on my sister laptop since I had an OS laying around so I put it on that, keep in mind that the laptop is about 8 years old and is a 32 bit processor but the CPU usage is good for the single core its just need atleast 1GB to actually run it well instead of half a gig, I do have 4GB of DDR ram laying around but its not for a laptop. I can't really really help you on a cooler because there really isn't good one for that prices.
Computer and other things (My Phanteks Enthoo Elite build is done)
Main Computer
Processor: Intel Core i7 6850k @4.5GHz
Motherboard: Asus Rampage V ROG Edition 10
Heatsink: Custom Hardline
Memory: Corsaor Dominator 16GB (4GB x2) DDR4 3000MHz
Video Card: EVGA GTX 1080 FTW
Hard Drive: x2 OCZ ARC 100 240GB RAID 0 (Boot), Western Digital 4TB SSHD (Steam), x2 Adata 512GB (Steam)
Main GUI: Windows 10 Pro 64-bit
All That Extra Stuff
Monitor: x2 Dell U2414H
Keyboard: Ducky Shine 5 RGB (Cherry MX Blue)
Mouse: Logitech G502
Headset: AKG K553 Pro Studio Headphones
Speakers: Boston Accustics Home Media Theater 2.1 + Boston Accustics Soundbar
Microphone: Audio Technica AT-2035 w/ Focusrite Scarlett Solo
Sound: Creative Sound Blaster E5 DAC
Server
Case: Rosewill 4U Rackmount RSV-L4500
Processor: Intel Xeon E5-2670 V3 12C/24T
Motherboard: Asrock x99 Extreme 4
Ram: Kingston HyperX DDR4 2133 4x4GB
Video Card: Nvidia GT520
OS Drive: Kingston Hyperx 240GB SSD
Raid Card: LSI MegaRaid  9261-8i 8-port
Hard Drives: x7 HGST 4TB Nas
https://linustechtips.com/topic/179534-need-a-cheap-cooler/#findComment-2414115
I think you should go with
Cooler Master Vortex 211Q
But i dont think there is much room for overclocking in it.
You should have no problems fitting it in your case.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/179534-need-a-cheap-cooler/#findComment-2414908
