The Koolance CPU-380i will kick both those water blocks asses!
The difference between waterblocks is really small, most of the time you get what's better for aesthetics.
http://www.xtremesystems.org/forums/showthread.php?285753-CPU-water-blocks-roundup
I'd have to agree with the differences being very very small. Though it might be 1 degree but I think it's pretty insignificant? compared to raystorm and stuff.
you mainly buy CPU water blocks on aesthetics and price.
the performance difference is margin of error.
go with what looks best in your build not the 2° someone said it is better.
Well IMO Swiftech's Apogee XL is good for it's perf/price ratio. It's even better than Supremacy by just a little tiny bit.
In terms of aesthetics, Apogee XL wins my heart cause it can suit my theme better. and custom non swiftech branded designs too!
What about quality control? Thanks for the advice :)
Both EK and Swiftech have top notch quality control and product support, they are great companies.
Personally I think XSPC, Heatkiller and Bitspower have the best looking CPU blocks, but everyone has their style.
Anyway whatever of those blocks you end up picking you'll be good, Happy Watercooling :)
Chose which one looks the best to you, they pretty much all perform around the same.
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
