need help with a new pc build
Solved by WoodenMarker,
No, that's not idle. Idle power draw should be below 100w. Pcpartpicker calculates power draw from TDP and not the actual power draw. 170w is the TDP of the 760 at load.
The system should pull ~350w at load. Also, no..you don't add the idle and max load--that's silly.
1. A decent 500w psu is already more than enough--any more is overkill. Something like the cx500 would be fine.
2. 80 plus bronze is pretty standard nowadays.
3. Everything is compatible.
i'll check it ... i had previously amd 3870x2 and i also have 650m in my laptop ... i think nvidia has better support
You need to quote a post or tag a member or else they won't get a notification you replied to them.
