I was discussing with a guy on the fact that he doesn't believe that my gpu in idle in the winter stays at 19°C. He keeps telling me that is impossible and that you only get a temp like that with watercooling. My room in winter is really cold usally 17°C and I think is normal with a room temperature like that to have a gpu temp around that number.
Maybe I'm just crazy and I'm remembering stuff that is not true, but I hope that you guys can solve this doubt for me!
Thanks in advance <3
https://linustechtips.com/topic/177260-idle-temps-780-asus/
I actually don't have any fan in my "case", is just a 40€ case without the panels. Does it matter when the temperature is detected? I mean is it lower just after turning on the computer or it doesn't change anything?
you need to throw some fans in it, just get some $5 nobrand ones.
My Little Gaming Rig:
CPU: FX 8320 | MOBO: Gigabyte 970A-D3P | RAM: G.Skill Ares 2x4GB | GPU: Sapphire Dual-X R9 270X | Storage: Seagate SSHD 1TB | Case: Corsair 200R | PSU: CM 550W V-Series
Upgrades to come: CPU FAN: Corsair H100i | RAM: 2 more 4GB sticks | GPU: Another R9 270X running in crossfire | Storage: Samsung 120GB SSD | PSU: Corsair 800w
https://linustechtips.com/topic/177260-idle-temps-780-asus/#findComment-2378598
I have 2 of them and they are both sitting at 25°C with an ambient temperature of 23°C.
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
https://linustechtips.com/topic/177260-idle-temps-780-asus/#findComment-2378650
Depends on which temp you're reading, core or CPU (tin). Core temp is usually lower.
https://linustechtips.com/topic/177260-idle-temps-780-asus/#findComment-2378675
