Problem with the case
Go to solution Solved by mgsstar,
Ok if i connect it i will see it in computer tap ?
Yea if you insert your hard drive at the top it would show up in your OS/UEFI if you plugged every thing in properly.
Hello
I have now thermaltake v9 black edition i have hard drive in the top like this
http://cdn.itechnews.net/wp-content/uploads/2010/06/Thermaltake-V9-BlacX-Edition-with-Dual-Bay-HDD-Dock.jpg
When i put drive in the top nothing happen in my pc i try Two types of hard drive i put them but but nothing happen please i need help how i can make the drive work in the top
https://linustechtips.com/topic/177101-problem-with-the-case/
Make sure the cable is properly connected
https://linustechtips.com/topic/177101-problem-with-the-case/#findComment-2375886
Hello
Make sure your Sata power and cable connections to the hot swap bay are connected (power from the power supply and the sata cable from your bay to your motherboard) (also if applicable set the sata port that you plugged your bay into as hot swappable).
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/177101-problem-with-the-case/#findComment-2376600
https://linustechtips.com/topic/177101-problem-with-the-case/#findComment-2380370
