Hey guys I am currently investing in a new sound card. At the moment it is the ROG Xonar Phoebus, but their is a problem... where does the sound card go and will it go with my build?
Yer I know I sound like a noob.
My PC build:
CPU: i7 3820
OS: Windows 8
RAM: 16GB Hyper X Ram
Cooling: CORSAIR H55
Motherboard: ASUS RAMPAGE IV FORMULA
HDD: 2TB
SSD: KINGSTON 240GB SSD
GRAPHICS: ASUS GTX 680
PSU: Huntkey X7 900W PSU
ODD: LG BLURAY COMBO
MOUSE: RAZER NAGA EXPERT MMO GAMING MOUSE
KEYBOARD: RAZER BLACKWIDOW ELITE 2013
MONITER: ASUS VS247H
LOL forgot to add my headphones, I currently have the Razer Kraken 7.1.
https://linustechtips.com/topic/176892-sound-card-help/
What do you mean "Where does it go?"
Like. Physically?
What audio stuff will you be doing?
I really wish that we'd just make organic hardware already, that grows and adapts to the demands it needs to meet. That way, grannies' computers can be floppy sacks of organicness and the 12 year old Minecrafters will look like the guys that only do bicep curls, and the nerdy programmers will finally have justice, with their body-builder rigs that skipped leg day.
CPU: i7-4770k 4.8GHz | Motherboard: Asus Maximus Hero | RAM: 16gigs 2133MHz | GPU: SLI Gigabyte OC 2gb 770's | Case: INWIN GRone | Storage: 1tb Blue, 60gb SSD | PSU: Silencer MK II 950w | Cooling: Modded H100i
https://linustechtips.com/topic/176892-sound-card-help/#findComment-2372790
You need to invest in pretty fantastic headphone before thinking about getting a sound card. Onboard is fine for most things. You need very serious headphones before you need a dedicated sound card.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/176892-sound-card-help/#findComment-2372894
what headphones for example?
Usually it's headphones over 80 ohms and are not able to drive loud enough on onboard that will benefit from a sound card. But even then a Fiio E6 is usually a better solution.
https://linustechtips.com/topic/176892-sound-card-help/#findComment-2375973
But why spend money when onboard can still drive headphones up to 150Ω, with disregard to damping factor.
Which is why I said over 80 ohms and can't be driven loud enough by onboard. 150 ohms just seems like you're pulling a number out of thing air xD
https://linustechtips.com/topic/176892-sound-card-help/#findComment-2376357
And you're not?
https://linustechtips.com/topic/176892-sound-card-help/#findComment-2376400
very interesting. and what about other components of the sound card? DAC and everything
DACs do nothing more then turn data into an analog sine wave. Now one DAC can't make a better sine wave then another* its more dependent one the file. And since machines struggle to hear the difference between a 256kbps 16 bit file and a 320kbps file, you can't tell a difference either. And other things like caps don't change sound, and the only emi shield short of a Faraday cage is distance.
*older DACs will not be as accurate, but that was 10 years ago....
https://linustechtips.com/topic/176892-sound-card-help/#findComment-2382637
