As title states
gimme yo good fan hub suggestions.
I've seen the sentry 2 and sentry mix 2 from nzxt and both look really nice, dunno which of the 2 I should get or if I should get something else.
i7 3770 w/ stock cooler - 16 gigs of 1600 mhz ram - AMD Radeon 7770 from Asus - P8H77-M mobo - no name 400w psu - 3000 GB HDD - 128 GB Sandisk SSD all housed in a matte black/red H440
thanks and have fun
https://linustechtips.com/topic/176786-good-fan-hubs/
The bitfenix recon is a good option, it looks good and has a USB connector that allows the whole thing to be configured by software in windows, much easy than struggling with the small screen.
I'm not familiar with the NZXT Sentry 2 or Sentry Mix 2, so I don't really know what they offer.
I don't know what type of fans you have, if you have all PWM fans (or plan to buy them), you can get a PWM splitter and control all your fans at the same time using the motherboard. like this one (only for PWM) http://www.frozencpu.com/products/20988/ele-1196/Swiftech_8-Way_PWM_Cable_Splitter_-_SATA_Power_8W-PWM-SPL-ST.html
https://linustechtips.com/topic/176786-good-fan-hubs/#findComment-2371053
I have 4 140 quiet corsair af series fans, 1 120 quiet I think, af series and 1 120 pwm sp series
thanks and have fun
https://linustechtips.com/topic/176786-good-fan-hubs/#findComment-2371144
As title states
Lamptron FC5v2 or FC5v3.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/176786-good-fan-hubs/#findComment-2372629
