I don't know what you mean by off-centered or why would you need it. Node 304 supports 165mm coolers as is.
 Yeah and the Coolermaster Hyper 212 is 159mm tall so I think it would fit,
 I don't think it is off centred that's just how Mini-ITX Mobos are arranged differently
https://linustechtips.com/topic/175583-cpu-cooler-help/#findComment-2352650
There are alot of ITX boards with sockets near the PCIe slot that are generally incompatible with tower coolers.
However, after taking a look at your mobo I'd say your biggest concern should be ram clearance as the 212 evo will have to overlap your ram. Being an ITX builder who uses a tower cooler currently, I'd look into liquid cooling as it works much better in smaller enclosures.
proud owner of alienware 13 with graphic amplifier and also a alienware X51 gaming PC!!! really powerfulL!!
xoxo samantha <3
https://linustechtips.com/topic/175583-cpu-cooler-help/#findComment-2353679
Will it also fit a Cougar Volant case? :D
i5 4690k @ 3.5Ghz | Stock Cooler :/ | ECS Gank Machine Z87H3-A2X EXTREME | Gskill RipjawsX 8GB 1600Mhz | MSI GTX 960 100th ME 2GB | Samsung 840 Evo 120GB | 1TB WD Caviar Blue | Seasonic m12ii evo 750W | Razer Modded Phantom 410
https://linustechtips.com/topic/175583-cpu-cooler-help/#findComment-2361169
It should fit perfectly as long as it doesn't collide with your ram. Although the Cougar Volant does only support matx/atx motherboards.
I have a 1stick G.skill ripjawsx ram. Installed at the First slot. Should I move it?
https://linustechtips.com/topic/175583-cpu-cooler-help/#findComment-2363028
What motherboard do you have?
Gigabyte GA-78LMT-S2 rev1
Ill soon upgrade to a 990FX-UD3
Sorry for invading this thread. Might as well ask instead kf making another thread xD
https://linustechtips.com/topic/175583-cpu-cooler-help/#findComment-2363105
It should be fine on the GIGABYTE GA-990FXA-UD3 as the two first sticks go farthest from the gpu. So you could get another stick too without problems.
http://www.tomshardware.co.uk/forum/341509-28-cooler-master-hyper-plus-gigabyte-990fxa
On your current board, you only have two slots. I can't say sure about your current board, but atleast you could fit one fan on the other side of the cooler. If you want to do push-pull on your current board, you may have to raise the fan near the RAM slots a little bit.
Yo mama so fat, she doesn't even fit in a 900d.
https://linustechtips.com/topic/175583-cpu-cooler-help/#findComment-2363272
