So I am going to be buying a windforce 290, a 840 EVO 250 GB, a 4790k, and maybe a Dark Rock Pro 3. I don't want a H100i because it is a little pricey. Please recommend a CORSAIR case around $150, or should I go BitFenix Ghost? Also RAM, atleast 8 GB per stick, 9-9-9-(I think 24 or 27), 1600mhz compatible with mobo max 32GB, around $85 per stick. Mobo has to have 4 16x slots, 4 ram slots, and obviously fit 4790k around $300 mobo. All USD$ Please answer quickly! Thanks.
I trip to make the fall shorter
https://linustechtips.com/topic/175304-first-build-not-overkill/
Got around 2k to spend on it (Parts only)
Okay, if you're gaming there's a lot of things you shouldn't spend that $2k on. RAM and a stupid motherboard for example. Also, don't bother with 3x or 4x graphic cards. You lose a LOT of performance for the money.
https://linustechtips.com/topic/175304-first-build-not-overkill/#findComment-2339839
