H440 Led Light Mod
By
pbenologa
in Cases and Mods
in Cases and Mods
Solved by Enderman,
Probably not. LED strips will use over 10W of power, something that small switch was not intended for. I would check to see if anyone has done it before, or if the switch is rated for that kind of power.
derekchan ·
Posted in New Builds and Planning4 -
1
5
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
