So I'm building a gaming PC that I want to try and keep around $1,100 US and I'm having trouble finding a motherboard with the feature set I want. It doesn't have to be in the "Gaming" category, especially as those tend to be more expensive. I'm trying to find one around $150 with my primary concerns being: Over-clocking, and since I'm over-clocking, good fan controls for the CPU and Case. I've seen many build videos of people using Asus's ROG boards and it's software but those even in Z87 are around $200 from what I have been able to find. Oh yeah and I'm using an LGA1150 socket.
https://linustechtips.com/topic/175147-motherboard-help-request/
what cpu?
Specs
https://linustechtips.com/topic/175147-motherboard-help-request/#findComment-2336858
If you can stretch your budget a little bit, get the http://www.newegg.com/Product/Product.aspx?Item=N82E16813128705&cm_re=gigabyte-_-13-128-705-_-Product (Gigabyte GA-Z97X)
Also, what CPU are you using?
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/175147-motherboard-help-request/#findComment-2336869
To be exact: Either the i5 4670k or of the board is Z97 the 4690k. Also, to add on to what I said about Asus's ROG boards, the ROG software seems to work really well for fan control, but of course ROG boards are over-budget unless on a $50 sale :/
Forgot to mention I'm looking for ATX.
https://linustechtips.com/topic/175147-motherboard-help-request/#findComment-2337029
this is one heck of a cheap board from MSI
http://pcpartpicker.com/part/msi-motherboard-z97pcmate
Z97 board
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/175147-motherboard-help-request/#findComment-2337046
I would actually prefer 4690k as at Micro Center I can actually get it cheaper than the 4670k on New Egg.
https://linustechtips.com/topic/175147-motherboard-help-request/#findComment-2337152
Do you have this board or any other MSI board? If so, how is the software? Like I said, I'm interested in good fan control.
the bios is very easy to understand and you use your mouse to change settings. I build system using msi and none have major issues. Fan control for msi is called easy fan.
https://linustechtips.com/topic/175147-motherboard-help-request/#findComment-2341195
Thanks, I'll probably end up going with the board you recommended. Really glad it's not black and red. After researching for a few hours and everything (not really but still, it's annoying) being black and red I was looking for something different :)
https://linustechtips.com/topic/175147-motherboard-help-request/#findComment-2341241
A little higher in the lineup is this one,  SLI support, better all around...
Motherboard: MSI Z97-G55 SLI ATX LGA1150 Motherboard  ($118.98 @ Newegg)
Total: $118.98
http://www.msi.com/product/mb/Z97G55_SLI.html#hero-overview
This one has :
- 2 x 4-pin CPU fan connectors
- 3 x 4-pin system fan connectors
_____________________________________________________________________________________________________________
BUT, the best your 150$ budget would allow you to buy would be this board right here:
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($139.99 @ NCIX US)
Total: $139.99
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/175147-motherboard-help-request/#findComment-2341447
