some next level lag !
Those are pretty low speeds, did you check SMART to see if it's defective/dying? (with something like Crystaldiskinfo) Check the SATA cable too
no, ill get back to you.
is there a specific test i have to run? ive never used hdd programs before.
ill give you this screenshot while i wait for your reply
http://gyazo.com/39535a2f618990cf6c1c8b842056a4d1
https://linustechtips.com/topic/174837-some-next-level-lag/#findComment-2327553
What are the errors in G:\?
Also You try sector check with HD Tune (free version) on all HDDs, it's useful to prevent data corruption
also which one is the SSD? or are you using the integrated SSD in the SSHD as cache? Did you defrag the SSD (NEVER do that...)?
And looking at the seek error rate, that might explain that poor performance and it's an indicator that in a future the head would stuck
http://gyazo.com/d2f3c311d58d3e2a44749bac6c5b9462
no idea what you mean by sector check, ive never used this, where is this?
i dont have an ssd, i think my primary is a hybrid
https://linustechtips.com/topic/174837-some-next-level-lag/#findComment-2328037
If it shows damaged sectors then you'd do a backup as soon as you can.
If it doesn't, try running MC (installing java and all that crap, don't forget to change MC files folder too in the launcher) in a different drive (different than C:\ and H:\ (SSHD)). That SSHD has a bad head, you'd get a different drive or RMA it.
sadly same result, test seems good so far
https://linustechtips.com/topic/174837-some-next-level-lag/#findComment-2328541
Then install java in a different drive and move mc folders too.
No data damage danger but that head is causing that low speeds, that messes up chunk loading causing low framerate
i installed minecraft into a different hdd (was still 20fps) but i will now try java too.
https://linustechtips.com/topic/174837-some-next-level-lag/#findComment-2328621
crash O.o? Paste here.
But did you move MC FOLDER in profile settings in the MC launcher?
00:39:20 INFO]: Client> # A fatal error has been detected by the Java Runtime Environment:
[00:39:20 INFO]: Client> #
[00:39:20 INFO]: Client> #  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6925d858, pid=6116, tid=1160
[00:39:20 INFO]: Client> # JRE version: Java SE Runtime Environment (7.0_60-b19) (build 1.7.0_60-b19)
[00:39:20 INFO]: Client> # Java VM: Java HotSpot Client VM (24.60-b09 mixed mode windows-x86 )
[00:39:20 INFO]: Client> # Problematic frame:
[00:39:20 INFO]: Client> # C  [atioglxx.dll+0xc4d858]
[00:39:20 INFO]: Client> # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
[00:39:20 INFO]: Client> # An error report file with more information is saved as:
[00:39:20 INFO]: Client> # E:\.minecraft\hs_err_pid6116.log
[00:39:20 INFO]: Client> # If you would like to submit a bug report, please visit:
[00:39:20 INFO]: Client> #   http://bugreport.sun.com/bugreport/crash.jsp
[00:39:20 INFO]: Client> # The crash happened outside the Java Virtual Machine in native code.
[00:39:20 INFO]: Client> # See problematic frame for where to report the bug.
[00:39:20 INFO]: Client> AL lib: (EE) alc_cleanup: 1 device not closed
[00:39:21 ERROR]: Game ended with bad state (exit code 1)
[00:39:21 INFO]: Ignoring visibility rule and showing launcher due to a game crash
[00:39:21 INFO]: Deleting C:\Users\Eihcal\AppData\Roaming\.minecraft\versions\1.7.10\1.7.10-natives-2464201085557
[00:39:21 WARN]: Couldn't delete C:\Users\Eihcal\AppData\Roaming\.minecraft\versions\1.7.10\1.7.10-natives-2464201085557 - scheduling for deletion upon exit
https://linustechtips.com/topic/174837-some-next-level-lag/#findComment-2328852
-Try this, http://support.amd.com/en-us/download/desktop/previous/detail?os=Windows%207%20-%2064&rev=13.12#amd-catalyst-packages
There was some problems with some AHCI drivers, but I don't think it'd cause that gross framedrop
-Check if mc files are read only, if they're, unmark read only.
-When did this started to happen
you want me downgrade?
-will try that
-once i got the r9 270x, even my 8800gt was better
https://linustechtips.com/topic/174837-some-next-level-lag/#findComment-2329522
