Soooo today i hopped on to play bf3 and i experienced hardcore stuttering. After about a minute of just feeling like 600 ping and about 2 fps i black screened.So i restarted my PC and tryed again. This time the same thing happened but i left before the black screen.I got a error saying repair game or something so i did the steps and it happened again. Then i opened msi afterburner and it showed 99 percent then a spike to 17 then 99 spike to 17 on load. So anyclue what this means? I dont have any other graphically challenging games to test. i only have civ 5. Also PC slow now. might be my internet.
EDIT: Just ran bf3 again for about 2 min and afterburner was dead for a while then one spike then dead and one spike.
† TTCF Member † Jesus loves you! Have a good day and stay techie!
https://linustechtips.com/topic/174488-gpu-problem/
If i was you I would change the name of the topic fast :/
CPU 5900x| GPU 3080ti FE| MOBO MSI MPG CARBON MAX| RAM 32GB VENGENCE PRO 3200Mhz| STORAGE Samsung 980 Pro 1TB,2X WDSN750,4TB Seagate Barracuda| COOLING 1x Corsair 360mm XR7 54mm Radiator,1x EK-CoolStream PE 360mm Radiator| GPU Block: Corsair Hydro X Series, XG7 RGB| CPU Block: Corsair Hydro X Series, XC5 RGB| Fittings: EK-Torque STC & Corsair Hydro X Series XF| Pump/Res: EK-Quantum Kinetic TBE 300 D5| Tubing: Corsair Hydro X Series XT Softline| Liquid: Corsair Hydro X Series XL5 Clear| Fans: 10x Corsair SP120 RGB
https://linustechtips.com/topic/174488-gpu-problem/#findComment-2317412
thanks ;D
https://linustechtips.com/topic/174488-gpu-problem/#findComment-2317425
