HELP ME PLEASE PC BLACKSCREEN
Solved by dragoon20005,
i try my radeon 5570 on my second pc the graphics card still work
that mean the problem not on the GPU
Maybe CPU Or RAM
I Already Check The Both And Nothing Broke
this form of troubleshooting will not get you anywhere
you need to take everything apart to check each part one by one
do not use your gut feeling this whatever part is working
anything can affect each other
you need to check each and every thing out
like i said we can't help you unless you help yourself
