DRIVER HELP!
Go to solution Solved by dtronicsuk,
I installed Java, I need audio so I could atleast play 1 game, I don't have enough MB for AMD catalyst, but I could ask my grandperents to refill it (played bbal°l and fell on my ankle  ripped somethong in there)
click on the mobo drivers link i posted and look for audio (you might have to select windows 8 64bit)
EDIT::
audio drivers here -> http://download.msi.com/dvr_exe/realtek_hd_audio.zip
Can you tell us your PC specifications? Was it a pre-built PC?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/173821-driver-help/#findComment-2308232
Drivers? Hmm just list your hardwate and at the end add "drivers" without the quote. e.x: R9 280X Drivers or MSI 970A-G43 Drivers
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/173821-driver-help/#findComment-2308241
So:
CPU: AMD A6 6400K
GPU: R9 270 (Gigabyte)
MOBO: MSI FM2-A55M-E33
RAM: CRUCIAL 8GB (2X4GB)
Windows 8.1 64 bit (cracked)
For AMD search on their website for drivers, theres catalyst driver which updates your gpu to the latest one and for the cpu.. as far as i know you dont need a drive for the cpu
for the mobo just use the cd...
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/173821-driver-help/#findComment-2308279
So:
CPU: AMD A6 6400K
And which bit of hardware do you need drivers for, if you let me know i can find you the drivers
EDIT::
mobo drivers ->   http://uk.msi.com/product/mb/FM2A55ME33.html#/?div=Driver&os=Win8.1 32
GPU drivers -> http://www2.ati.com/drivers/14-4-win7-win8-win8.1-64-dd-ccc-whql.exe
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
https://linustechtips.com/topic/173821-driver-help/#findComment-2308303
EDIT::
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
https://linustechtips.com/topic/173821-driver-help/#findComment-2308331
