How much are you willing to spend?
N64 HTPC: [Completed]
Main PC: i7 4770k @ 4.2 Ghz | Be Quiet! Dark Rock TF | Asus Z87 Maximus VI Formula | G Skill Ripjaws X 16GB | Zotac GTX 1070 | Samsung 850 EVO 500GB | Seagate 1TB Hybrid | Samsung 840 EVO 128GB | Corsair 1200i | Thermaltake Core P5
https://linustechtips.com/topic/173225-cooling-problem/#findComment-2301497
max 60 dollars
Please use the basic text size, it makes it more easy to read. And what are you asking? Do you need a whole new Air cooler, or a new fan? If a new cooler budget?
a new fan
https://linustechtips.com/topic/173225-cooling-problem/#findComment-2301504
 I have a problem of cooling my cpu is getting up to 90-100C
i have a:
intel i5
intel basic air cooling
max 60 dollars
There's no way its getting that hot... Either its a messed up sensor or the fans stuck on something.
Gaming rig- Cpu- Amd 9590, 16gbs of G Skill Ram, Gpu- GTX 760 windforce 3 edition 2gb. A Thermaltake water 2.0 water cooler for my cpu. Keyboard- Thermaltake Posieden , Case- 750D, Mobo Asus 990fx R2.0. 24 inch Dell LED monitor
https://linustechtips.com/topic/173225-cooling-problem/#findComment-2301520
or hes overclocking
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/173225-cooling-problem/#findComment-2301555
no
Then your fan isnt working, its running WAY too slow or you screwed up when you put it on. First check the first two I listed and if its not those then go buy some thermal paste, most computer stores have it and Best Buy has Arctic Silver I believe, wipe the old stuff off the cpu and base of cooler with rubbing alcohol with toilet paper and then go over it with a micro fiber cloth to get fibers off and put the paste on the CPU (Size of Pea) and press the heatsync into it trying not to lift, wiggle or shit while locking the clips in place.
If your looking for a cooler to replace the stock cooler and not OC look at the Zalman Ultra Quiet CPU Cooler or the Hyper 212 EVO
If you want to overclock start looking at larger ones like the NH-D14, Cooler Master V8 and watercooling solutions like H75, H110, H100i, H105
| F@H STATS |
https://linustechtips.com/topic/173225-cooling-problem/#findComment-2301574
It may be that case has poor ventilation or cablemanagement is blocking airflow. 212 should do the trick anyway.
Poor ventilation wouldn't cause temps like that for that processor.
https://linustechtips.com/topic/173225-cooling-problem/#findComment-2303184
I would get a new cooler, and a ap123 fan for it.
https://linustechtips.com/topic/173225-cooling-problem/#findComment-2303195
Like what @spwath said, get a new cooler? Are you willing to spend 30 bucks on a cooler? Stock coolers are crap, even when no OCs happen, and plus, they are as noisy as hell. I would get a really quiet 212.
https://linustechtips.com/topic/173225-cooling-problem/#findComment-2303368
