post-4413-0-38140300-1403921291_thumb.pn
So here I have a completed Ghetto Rig made up of spare parts and slightly damaged parts that I had around the house or had taken out of my main Rig. I took the motherboard, CPU and one PSU from an old Dell Inspiron 530 and the GPU was an overheating one taken from my main Rig. The second PSU was in my box of spares, not sure where from and the Antec 300 was from my old rig.
post-4413-0-04262600-1403921365_thumb.jp
So having these parts disused was annoying me, and I decided to see what I could create from them. I knew the Dell's PSU (305w) wouldn't be enough to power the 6970, so I looked into dual power supplies, and came out with what you see below.
One PSU for the Mobo/CPU and accessories and one for the Graphics card. There were a couple of methods to setting up dual PSUs, such as splicing them together so that the one switch would turn on both, but I wanted to be able to easily dismantle this machine if I had other/better uses for the parts. Instead I used a light switch mounted to a 5 1/4 " cover at the front, with the cables plugged into the relevant plugs on the 24 pin adapter.
post-4413-0-00059500-1403921362_thumb.jp
post-4413-0-71567400-1403921362_thumb.jp
I drew on the symbols to remind myself ;)
The whole build only cost me around €5 for the switch and cable, the rest of the parts were free, and I now have a pretty decent spare rig, but I'm not sure how long the HDD will last, it's nearly dead.
List of specs are as follows:
Intel Core 2 Duo E6650 @ 2.33Ghz
2GB 800Mhz DDR2
Dell Inspiron Motherboard(P35)
HIS Radeon HD 6970 2GB (Reference)
2x 305w Generic PSU
Antec 300 Mid Tower( All 4 fans filled)
750GB Generic HDD
1x Lightswitch ;)
Here are some screenshots of CPU Z etc ( I know that everyone hates Windows Experience Index - But I don't )
post-4413-0-67179400-1403921367_thumb.pn
post-4413-0-94163900-1403921369_thumb.pn
post-4413-0-17142100-1403921378_thumb.pn
post-4413-0-28722400-1403921360_thumb.jp
Main Rig:
AMD FX 8320 @4.5Ghz  8GB Corsair Vengeance LP Blu 1600Mhz Sapphire Vapor X HD 7950 3GB 120GB Samsung 840 Evo  Asus M5A99FX PRO R2.0
Corsair 600T Graphite Corsair H80i Corsair CX600 2x LG 24 inch LED @1080p Logitech G700s CM Quickfire TK (Brown)
Home Server:
A4 6300 @3.7Ghz 5GB Kingston/Crucial DDR3 1600Mhz 1TB WD Green 2TB Seagate Barracuda
500GB WD Blue 2x Gigabit NIC Antec 300 OCZ 500w PSU Gigabyte F2A68HM-HD2 R1.1
https://linustechtips.com/topic/172725-project-ghetto-rig/
Just not sure what to say right now ...
but hey give me that video card for my son's socket 775 dual core rig.
You wouldn't want it- maxes out at 90c on easy running games like Wow ;)
Main Rig:
Home Server:
https://linustechtips.com/topic/172725-project-ghetto-rig/#findComment-2295387
I CANNOT GET OVER THE LIGHT SWITCH ON IT that's fucking mind blowingly amazing 10/10 for that alone.
Seemed like the best solution even if it does look ridiculous lol
Main Rig:
Home Server:
https://linustechtips.com/topic/172725-project-ghetto-rig/#findComment-2295388
Now I want a light switch
https://linustechtips.com/topic/172725-project-ghetto-rig/#findComment-2295410
You could've left that drive bay cover in place, cut a hole for the switch and secured it that way. Would look more factory lol. But hey not bad for spare parts. ;)
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/172725-project-ghetto-rig/#findComment-2295433
I know what you mean, but one of my main angles for this was that I could take it all apart and have no damage to any of the parts. Cutting up stuff is too final for me :/ Especially when it's only for the sake of using up parts.
Also- I don't think that would work looking at the measurements- I think i would have had to cut 2 of the covers, because under the 3rd cover is a metal plate, and that would have gotten messy
Main Rig:
Home Server:
https://linustechtips.com/topic/172725-project-ghetto-rig/#findComment-2295455
I like it. :D
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/172725-project-ghetto-rig/#findComment-2295892
  • 2 weeks later...
