I just got my XFX 290X back from RMA. They sent me a 290X DD Edition when I had a reference 290X. I did a quick OC and ran valley to see what I could get from it. Once the bench was finished, I checked GPU-Z and HOLY BALLS! My VRM temp was HOTTT! I know this is not safe, but with my reference 290X, my VRM temps were way lower. Take a look at these screenshots from GPU-Z.
Here were my OC settings I used
And here are the screens from GPU-Z
CPU  i7 6700K @ 4.7GHz | Cooler: Swiftech H220 | RAM: 16GB Corsair Vengeance | GPU: EVGA GTX 1080 SC | Motherboard: Z170X Gaming 7 | PSU: EVGA G2 650W
Storage: 128GB Kingston SSD/1TB WD Black Storage | CASE: NZXT Switch 810 | MONITOR: Acer GN246HL | KEYBOARD: CM Quickfire TK (MX Blue) | MOUSE: Sensei Rival
https://linustechtips.com/topic/172398-scary-290x-vrm-temps/
Xfx coolers just suck and the repair centre guys don't know what they are doing i had a broken 7970 send it back but they fixed it half still artifacts had to send it back another 4 times and then they finally fixed the problem.
Well they sent me a non reference card when I had a reference card. The new one I got is working good its just that VRM 1 temp is too hot.
https://linustechtips.com/topic/172398-scary-290x-vrm-temps/#findComment-2291291
They always do this I send a refrence 7970 and got a piece of shit double d back.
My reference 290X had better VRM temps. At least the core is way cooler.
https://linustechtips.com/topic/172398-scary-290x-vrm-temps/#findComment-2291300
Put it back on stock, run valley and see if it's your oc's fault. If it's not, then blame xfx
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/172398-scary-290x-vrm-temps/#findComment-2291343
Lower your memory clock, but leave your core clock where it is. Monitor that.
The core clock gains are the best out of the two so focus on that being the highest while keeping those VRM's down via not having your mem OC so high.
It's a beast and doesn't need the MEM OC anyway :) So don't overclock both on this card, just the core clock as much as you can. (maybe core @ 1175mhz or higher with 1250mhz MEM)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/172398-scary-290x-vrm-temps/#findComment-2291358
Will buying higher quality thermal pads lower the vrm temps?
https://linustechtips.com/topic/172398-scary-290x-vrm-temps/#findComment-2292377
Probably not, it's just due to the design of the cooler. Just curious, why did you RMA your last one? Mine randomly crashes about once every 2-3 hrs of gaming and I I could get an aftermarket cooler back, it might be worth sending in...
Edit: Here's a XFX 290 DD Review (same thing basically) and they too had ridiculous VRM temps http://www.legitreviews.com/xfx-radeon-r9-290-double-dissipation-video-card-review_138612/12
CPU: Intel i7 4770k w/Noctua NH-D15, Motherboard: Gigabyte Z97 Ultra Durable, RAM: Patriot 8Gb 1600Mhz (2x4Gb), GPU: MSI R9 390x Gaming,
SSD: Samsung 840 EVO 1Tb, HDD: Caviar Black 1Tb, Seagate 4Tb Hybrid, Case: Fractal Design Define R4, PSU: Antec Earthwatts 750w
Phone: LG G2 32Gb Black (Verizon) Laptop: Fujitsu Lifebook E754 w/ 1TB Samsung 840 Evo SSD Vehicle: 2012 Nissan Xterra named Rocky
https://linustechtips.com/topic/172398-scary-290x-vrm-temps/#findComment-2292428
Use after burner or something to make your own fan profile. That'll lower temps all around, for both the core and vrms.
https://linustechtips.com/topic/172398-scary-290x-vrm-temps/#findComment-2292556
Just ran my top card through furmark. The gpu reached 86C at 100% fan and the VRAM hit 109C. When I have both cards going they reach GPU temps in the 90s and the vram just slightly higher than before. This is in furmark full max load. I'm inclined not to worry. They are very hot cards.
Just ran a furmark run on my reference 290 and maxed out at 73C and 83C on the VRMs... to bad it sounds like a vacuum
https://linustechtips.com/topic/172398-scary-290x-vrm-temps/#findComment-2293081
I like those temps you have. Granted mine is blowing hot air right back at itself but still... definitely toasty in the summertime.
Yeah, I can only game in the evening/night or the mornings. Once it gets to ~83 F ambient in my room its not too fun anymore.
https://linustechtips.com/topic/172398-scary-290x-vrm-temps/#findComment-2294438
