Need help picking graphics card
I'm trying to get the best for my money on the gpu, would you guys prefer to use AMD or Nvidia, for a setup like mine?
For the GPU, definitely AMD. There are big gaps between the GTX 750 Ti, GTX 760 and GTX 770 which AMD fills up perfectly.
For the CPU, I'd go with Intel unless you don't mind crazy power consumption and enjoy the art of overclocking. Do note that your typical overclocked Vishera part will consume twice to thrice the amount of power compared to its equivalent Intel part. Given that, it will also cost you more as you will need a better (and more expensive) power supply to deal with it. If you get an Intel part and have zero plans of overclocking the CPU, you can get away with a super cheap $40-50 motherboard and suffer virtually no bottleneck. You'll need to spend at least $100 for a good AMD 990 motherboard to do any worthwhile overclocking of an FX-8xxx or higher part. That $50-$60 difference can go towards other stuff. Last, but not the least, you'll need to spend at least another $30 on a decent cooler for overclocking the Vishera part. i.e. Coolermaster Hyper 212 EVO
Anyway, for the GPU, here are my recommendations. Just work the budget yourself.
If you're looking at the GTX 750 Ti, get the R7 265. If the GTX 760, get the R9 280. In between those, I'd get the cheapest R9 270X. AMD's solutions are significantly faster if you compare directly priced parts from both sides. Personally, I believe the R9 280 will give you the most bang for your buck as it can play many titles at 2560x1600 with good framerates. No one can say the same for similarly priced GTX 760.
Hey guys, I'm going to build a PC soon but I'm not extremely good with hardware, i know a bit about PC's but not enough. I want it mainly for gaming. Here are the specs that I'm aiming to get.
CPU: AMD FX-6350
GPU: GeForce GTX750Ti Evga FTW edition
Memory: Kingston HyperX Blue DDR3/1600mhz Dual Channel (2x4GB)
Board: Gigabyte GA-970A-DS3P AMD 970 Chipset
HDD: 1TB WD Caviar Black
Will i get any problems with this setup? I've before been recommended to get a better GPU, what do you guys think? Thanks in advance for any help.
If you don't mind me scrutinizing your build, here's my alternative:
CPU: Intel Core i3-4150 - $130: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116995&cm_re=i3-_-19-116-995-_-Product
Board: ECS B85H3-M (AMD Crossfire capable) - $56: http://www.newegg.com/Product/Product.aspx?Item=N82E16813135355R&cm_re=lga1150-_-13-135-355R-_-Product
RAM: G.Skill RipJaws DDR3-1600 CL7, 4 GB x 2 - $80: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231308&cm_re=g.skill-_-20-231-308-_-Product
HDD: 1 TB Seagate Hybrid SSHD - $85: http://www.newegg.com/Product/Product.aspx?Item=N82E16822178381&cm_re=seagate_sshd-_-22-178-381-_-Product
Some notes:
1) RAM with better timings are better than higher clocked RAMs. The performance difference is actually tangible.
2) The Seagate Hybrid SSHD is significantly faster than the WD Caviar Black, especially if your tasks are repetitive. i.e. you only use a handful of apps and games on your PC frequently. I can attest to this. If you're not confident, just look for reviews of the Seagate Hybrid SSHD.
3) Your choice of PSU will depend on your GPU. Since this is an Intel build that emphasizes power efficiency, you can get away with a cheap, but good quality 450W PSU with an R9 280.
4) Personally, I'd go for the Core i5-4460 ($189: http://www.newegg.com/Product/Product.aspx?Item=N82E16819117302&cm_re=i5-_-19-117-302-_-Product) It's $60 more than the Core i3, but it's virtually as fast the latest Core i7 on any title. Not surprising since the Core i5 and i7 both have the same number of physical cores: four.
